Radio Display Flickers in 2015 Tahoe
Shana
Has anyone had any issues and if so, how did y’all get it fixed? My radio display flickers a lot and changes channels, disconnects my phone, turns radio from XM to AM.... this is very annoying
Tahoe14
Central Fl
Welcome. Sounds like a loose connection or a problem with the radio. You may also try a Google search and see if anyone has had the same issue.
bad_idea
Mine has started doing the same. I replaced the battery and the negative ground cable (they were due). Did not fix issue. I was hopeful but knew it likely wasn't my issue. Anyone else with same issue and find a fix? Thanks.
BenK
