reprograming onboard computer with new shocks
geodavky
Dealer gets error code C0590-04 on my 2009 Tahoe with Z55 air shock system which they say indicates needing a right rear shock. The labor estimate is $265.00 to install the shock and “reprogram the computer”. I asked the service writer if reprogramming the computer meant to just clear out the “service suspension system” out of the system and he said no that the computer has to be reprogrammed to account for the new shock in the system. I have not seen any mention anywhere on the internet of having to reprogram the computer when a new shock is installed. Does anyone know anything about this?
mikeyss
Longmont, Colorado.
I just replaced all of my Z55 suspension on my 09 Tahoe LTZ 6.2 and you do not have any reprogramming of any sort. I even had 'service suspension' come on and after replaced my bad compressor, the warnings went away immediately. But the price your dealer is quoting you is really good. However, I would not recommend replacement of just one rear shock.
kbuskill
NE. FL.
The shop manual says:
"Important: Whenever repairing and/or replacing ALC system components, perform the Suspension Position Calibration procedure."
James,
Is a Tech2 required for this procedure or is it not that complicated?
I've replaced my rear shocks and vompressor in my 02 and the warnings went away. The calibration requires a tech 2 which I didn't have at the time. I don't believe it's necessary.
kbuskill
NE. FL.
I too have replaced my rear shocks with the Arnotts and have replaced the compressor as well in my '08... never did any recalibration of any kind and no lights on dash.
hmm, I guess I probably need to do this then also but haven't had any problems
Trimset Recalibration If the system is functioning abnormally, performing the Bumpstop and ALC Trimset recalibration procedures may correct the condition. When a system component has been replaced, the Bumpstop setup and ALC Trimset procedures must be performed.
1. Ensure that the vehicle has a full tank of fuel or add sufficient weight to the rear of the vehicle to simulate a full tank of fuel.
2. Place the vehicle on a flat level surface. Ensure that the suspension is in the normal resting position. With a scan tool, perform the ALC Trimset procedure by following the screen prompts.
3. With a scan tool, perform the suspension Bumpstop setup procedure by following the screen prompts. Once the process has been completed, the system should be fully functional.
kbuskill
NE. FL.
I could see going to that much trouble if the ESCM were replaced but beyond that I doubt it's necessary.
It appears to me that the purpose of recalibration is to establish the proper ride height with the ESCM with the vehicle full of full but otherwise empty. I think we'll be seeing more Tech2 users in the near future! ;)
I replaced my ESCM at one point with one from Ebay when I was troubleshooting and never had to calibrate.
I thought the ride height sensors were supposed to do that. I have pulled an air line before when working on ride height, when I was adjusting the length of the sensor rods in order to get my final height perfect so I was level and my 26's didn't rub, so it would air up to it's final height, and it always just aired until the sensors said it's high enough. It seems like a simple enough system.
TU1881
