SnowDrifter
- Joined
- Sep 5, 2016
- Posts
- 2,418
- Reaction score
- 2,613
Here's one for you... I can't make heads or tails of it
When I got my truck it had some free play from both inner tie rods and the lf outer tie rod.
I replaced inner/outer tie rods, pitman arm, idler arm, and idler arm bracket with moog parts. They're a bit stiff, takes more effort to turn the wheels while in the air and the car is reluctant to return to center.
I got it aligned by a friend as I don't have access to an alignment racks. It's the new hunter Hawkeye laser stuff, pretty precision.
Well since replacing everything I can turn my wheel 1 turn in either direction. Any more than that and the front wheels bind and skip. It feels similar to it being in 4x4. It's an odd sensation as it feels like my turning radius increases when the tires bind and skip. It did it before the alignment as well but I had assumed it was a toe issue.
Alignment angles are all good, dead in the center of spec. I've verified that I am NOT in 4wd. I can climb under and the front driveshaft spins freely. I can jack up the front, 1 side at a time and spin the wheel freely.
I'm not entirely sure where to go from here
