Should I e85 swap my 02 Denali with a full chopacobra cam kit
danman22
Been thinking about doing it just want to hear the do’s and don’ts
Mudsport96
40.923,-89.488. Illinois
What all is done to the engine other than the cam? Unless you are going forced induction or running high compression e85 is lost on you. You could use it as a flex fuel option which can be nice sometimes. But, you would see minimal power gains unless you plan on strictly running e85 and tuning to the max for it.
petethepug
Michael
SoCal
The fella in that video needs to add some aftermarket, better flowing heads to the headers and e50 fuel to get to the 400 hp mark. Not sure what motor he's tuning either.
Mudsport96
It is a 5.3, and you need to realize these numbers are at the wheels. The stock heads are fine, they have the best cfm flow to combustion chamber size for a 5.3. Aftermarket heads tend to make more horsepower at the expense of low-end torque....which is fine in a lighter car. In a truck/suv you want all the torque you can get. The 706/862 is the perfect head for a sub-500 hp engine. A 400 hp AT THE WHEELS 5.3 is closer to 500 at the crank. And that my friend is a rowdy engine.
He is already making at the wheels what gm rated these vehicles at the crankshaft. That is a vast improvement.
bl74
