Spark Plugs when supercharged
Thrust
ICT
So for adding a magnuson supercharger to a 2015 Denali, do I stay with stock plugs or go with plugs for factory 6.2L supercharged GM applications?
gat0r
DFW
mine runs fine w/ stock plugs
even after i got a BBP tune. ;)
now that i am chasing more HP, i will go w/ a set from camaro ZL1,
after i do a few other supporting mods
STORMIN08
when adding a power adder, i would always lean towards a slightly colder plug.
just as an added insurance against detonation, understand that the COLDER temp range is the length of the body, thus allowing a little more heat dissipation in the area around the electrode. reason i state that is the length of the plug may have ill affects. if a colder plug is not achievable, then the tuning will have to accommodate and thus leave a little power to had, but not available
jacblev
