Steering wheel locks up
TexasTiff
2004 Denali XL
My steering wheel locks up every time I go into the same parking lot. It has a slight dip entering and then I usually turn right as soon as I enter the parking lot. Less then a minute after that I can’t turn my steering wheel. I have to let my truck roll into a parking space, thankfully there are plenty, and then turn my truck off and back on. Sometimes a couple times. Then it’s like nothing every happened. Anyone know what this could be or had any similar issues?
I am new here by the way. Just trying to take care of my truck that is starting to have issues.
B-train
Ummm.......does it lock while running? Or after key removal? Sounds bound up to me, if the wheels are left turned to either side
T
TexasTiff
It is while driving, and it is shortly after I make the first right in the parking lot.
B-train
I wonder if you have a steering gearbox with excessive play that is causing some binding. Other than something severely worn in the suspension system allowing a tire to move to a weird angle at that turn
T
TexasTiff
Thank you! I’m new at all this and definitely not mechanically inclined. Any sort of advice or thought as to what I might want to check helps a lot. I will definitely look into that.
exp500
Do you happen to have a heavy keyring filled? Could be enough for a lock cylinder failure.
miccey1
