Mine is part time 4X4
Jacks and JACK STANDS transmission jack if you have one.
Remove Torsion bars torsion bar cross member make sure you make what go where left right and how everything is clocked I used my Daughters nail paint don't tell her LOL.
Transmission Cross member.
Y pipe, Disconnect all 4 each 02 senders at there plugs.
Starter just get out you're way you don't have to remove the whole thing just move it.
Oil dip stick tube
Transmission dip stick tube
Remove transmission cooler line you will loose very little trans fluid I put a plastic bag around mine so what did leak would not drip in to you're face as you under the car working on it.
Torque converter bolts from flex plate.
Remove Flex plate
Disconnect both driveshaft from diffs
Pull out spark plugs so it be easier to turn over motor.
Disconnect battery.
Disconnect trans cooler lines.
Remove optional heat shield right hand side of transmission next to trans oil pan, gives you more room to work.
15mm ratchet combo wrench will make you're job much easier.
Sockets extensions air tools if you have them.
A must in my book a inch pound and foot pound torque wrenches.
get all you torques written down so you know what they are during reassembly some of them are step torques.
Clean Clean clean take you're time.
It can be done by one person I have found out don't let the wife help she just end up pissing you off LOL.
Marv02, is your Tahoe a 2wd or 4wd?
Im trying to change out my rear mail seal and seal plate on my Yukon Denali. Can you briefly explane to me all the parts u need to remove to remove the transmission.
