Suburban tire suggestion thread
K
KevOLTZ
I appreciate all the help. I just want to do it right the first time and not have to buy twice or even three times ‍♂️
Trey Hardy
Eastern North Carolina
For example my 24x10 kmc wheels and 33/12.50s wouldn’t rub the uca but when I put stock 18s and 265s on the tires would rub on the control arm without running some sort of wheel spacer up front
K
KevOLTZ
The wheels I’m going to be running are black rhino raid 18x9 and I was hoping to do 33x12.5 but I fear I’m going to run the uca or sway bar being 12.5 wide?
Trey Hardy
You should be fine and if you ain’t get a set of those 1/4” wheel spacers for the front from advance or auto zone their cheap
Again most the time when I’ve ran into issue is when I was running tubular control arms (aftermarket)
omastylie75
