Temperature Blend Door Actuator 2021 Tahoe
buymorecamaros
Looking for someone who has replaced a front temperature blend door actuator on 21 or newer tahoe. Trying to find location and what is involved. Not getting heat in the front but works fine in rear. Appreciate any input.
StephenPT
St. Helens, OR
Driver's side footwell - take off the carpet cover (2 push-pins) and then you can look up in at the LH side of the HVAC system. You'll see the heater actuator toward the bottom of the case - 2 torx screws holding it on.
MrRuiz
