gmartin1215
- Joined
- Nov 9, 2012
- Posts
- 240
- Reaction score
- 103
I have a 2009 Tahoe 4x4 with the 5.3 and the 6l80 with 150000 miles.
Recently, the transmission has started having issues where it slips out of gear, or does not engage it. This has happened after stopping at a light with the front pointing up on a slight incline. I roll out in first gear, then seem to not engage the 2nd or 3rd gear where I am only revving the engine, like its in neutral. Eventually, after the vehicle has slowed down a bit I can get it to engage again and I can continue. Shifting and driving go back to normal. There were no codes thrown and I did not hear any clunking or popping. This has happened to me twice. When I got it home, the first thing I checked was the fluid level. At running temps (140 degrees), I did notice the fluid showed that it was at the bottom line of the area with hashes that say "Hot." I added a bit more fluid and have been driving around for the last couple days (at about 120 degrees) and have not had the problem occur again. I have not noticed any leaks.
I am suspecting there could be more going on than low fluid, but hoping that is all it was. What are some other diagnostics I can do?
