CMoore711
- Joined
- Jul 18, 2017
- Posts
- 1,220
- Reaction score
- 972
there is another problem. If you install modules, then most likely the awesome design of Yukon headlights and rectangular sectors will disappear. Plus it is not clear how the cooling will cope. In general, in order to understand what is inside, you need to disassemble Faro. And if we have a lot of Tahoe, then Yukon is a rarity. And it will be quite expensive to bring a broken headlight for disassembly from the USA)))
Yes the rectangular sectors or lens(s) would disappear, but they would now be replaced by the modules. Which is fine by me given the additional light output and performance you gain. The challenge would be how do you install the MTF modules in place of the OEM rectangular lens and still make the install look clean and OEM+ when the headlights are not powered on.
The challenge I see is there doesn't appear to be projector/module "shrouds" offered to be used in conjunction with the MTF Constructor LED modules. Like there are for typical 2.5", 2.8", & 3.0" Bi-LED projector retrofits to create a cleaner install.
Without taking measurements the OEM rectangular lens seems wider than the MTF Constructor 1.8" LED module.
As you mentioned it's hard to tell what's doable without disassembling an OEM headlight, but the OEM LED rectangular lens(s) might just snap into place either individually or as a single piece inside the headlight. If the OEM rectangular lens could each be cut/trimmed with openings for the MTF Constructor 1.8" LED modules to be put in place, then painted gloss black to match the rest of the OEM headlight housing I believe that may be a way to use the OEM rectangular lens as a "shroud" to the MTF LED modules creating an OEM+ look.
Here's a quick and dirty image paint on what I'm trying to refer to:
