Vents randomly blow hot air?
briarpatch
So....almost 4 years in....and, of course outside the original warranty, we had our first issue. The vents seem to randomly blow hot air...and even when we turn the a/c on...the air temp remained hot. I turned the a/c off....and then the hot air seemed to stop. Thankfully, we bought an extended warranty, but it would not do it for the tech at the dealership. Has anyone experienced anything like this?
Sad to say....but owned a Toyota Sequoia before this.....drove if for 12 years and 148000 miles...and replaced a weepy water pump...and nothing else. I'm hoping this is not an omen about this vehicle.
Big Mama
Virginia
Welcome to the forum from Virginia. The dealers are quick to say they can’t replicate the problem in my experience. Try an Indy that your warranty company works with. It sounds like there’s a leak. Mine was the condenser.
EddieC
Good luck with it.
We had a VW Passat that we loved but had to trade in when the dealer couldn't solve it. It could be 90 degrees outside and the auto HVAC would blast full heat from the AC vents.
The electronics are far beyond the average mechanics capabilities. They are probably beyond I.T. guys capabilities too.
Hobert
Downers Grove, IL
Condenser could be going out, known problem on earlier models.
I had a 2001 Yukon XL that would due that. Did it when the engine started to overheat. I figured it was one of those self protection modes. Ended up being water pump/ low coolant that triggered it.
hotrodford
