What do you think of the “water based solvent” parts washers?
Sam Harris
Texas
I’d really like to have a dedicated parts washer in the shop. I don’t like the cost, or really, the danger of having 20 gallons of flammable solvent in the shop. I was considering a Hobo Fraught parts washer. It’s cheap & $130, but the solvent will add up to around $300 I believe to fill it up. I watched a YouTube video of a guy using his, and he seemed pleased. He used I believe “crud cutter” in it, as a water based solvent.
I’m curious if anyone here has one, what they use for solvent, and whether it’s actually worth it.
Sam Harris
Sam Harris
Texas
Sam Harris
Sam Harris
Texas
Hmm.. so that’s a service I guess? I went to the Cintas website, and found it, but I’d rather have a dedicated washer I can use when I need it.
Ok, I re-read the post you provided. Thank you. These are definitely not cheap! lol. I am not seeing anything looking around that uses the “real” solvents anymore. Perhaps another victim of EPA “guidelines”?
grouch
I clicked the wrong button and ended up here. However, I'll toss my input in.
Where I used to work, I spent 10 years in the Still yard. This is where we refined A-5 crude into different asphalt products. While we did use some fairly strong solvents, we also used Dawn dish washing detergent. For instance, cleaning clothes in SA-47, a kerosene based solvent, cleaned the asphalt out but left a kerosene smell. After that, we used old wringer washers and Dawn to wash out clothes and that took the smell out.
I have since used Dawn in a pan with water to clean parts. When I do a "Farmer Chic" paint job, I'll use Dawn and a scuffer sponge to clean the body before sanding. Then I sand the body down, rinse it off and once dry, start putting the primer and paint on.
BlaineBug
Clown World
How many gallons does it take? Can you fill it up with something like Purple Power?
Sam Harris
Sam Harris
Texas
Yes, you can use any “water based” solvents. Purple power would be in that list. It’s a 20 gallon, so I believe you’d need around 12 to fill to the correct level.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I was thinking a table top or bucket sized one would work and use less solvent but how do you dispose of the solvent? I use a drain pan and some gasoline. Then I just dump it into my drain oil bucket.
Sam Harris
Sam Harris
Texas
That’s one HUGE benefit of the water based stuff. It’s not flammable. And, I’m not sure how you’d dispose of it.. I do have a rather aggressive red ant population out here however.. :flamingdevil:
Triplearon
