- Joined
- Aug 2, 2018
- Posts
- 6,606
- Reaction score
- 8,674
Perhaps it is the interface unit, which you had not previously mentioned. Is it properly grounded as well?
I replaced my alternator probably 2 months ago. I only have a Rockford fosgate 400x4 amp running my door speakers I don’t have my subs hooked up untill I can figure out what is going on. I will try replacing the power wire next. Thank youTo be clear, you are only getting the interference when the truck is running, correct? If that is the case, you likely have a dirty power wire, that is allowing the field generated by the alternator to intrude on your sound system. I don't know enough about sound systems in general, or yours specifically, so I'll stick to what I am familiar with: The alternator may be starting to fail. You get these sorts of transient issues when they start to fail, and you could start seeing a reduction in MPG. Alternately (no pun intended), your alternator may not be powerful enough to run everything.
Good luck!
