White smoke issue
Recently had white smoke pouring out of the passenger side tail pipe and a rough idle. Checked the coolant and it keeps showing low after being driven. The motor hasn’t overheating yet according to the gauge. Could this just be an intake manifold gasket? What other things should I be looking at?
Thanks
NickTransmissions
Sin City
The transmission bench
Thanks
In addition to the dry/wet compression test, also do a block test that confirms/denies presence of hydrocarbons in your engine coolant. If confirmed, time to yank and go through the heads. If engine has more than 140-150k or so, yank and overhaul it, if you determine head gaskets are needed.
The block test kits are avail at auto parts stores and on Amazon
Eman85
Pull the plugs, the one that is clean is the cylinder or cylinders with the problem. Steam is a great spark plug cleaner. Do a compression test and or do a coolant system pressure test. While the coolant system is under pressure and the plugs are out have someone turn the engine over with the starter while you watch. Don't stand in front of the spark plug holes.
Lonny
Hi team -
Just heard back from the GMC dealership with the diagnosis: they discovered that the connector hoses are leaking. It's a $3,000 job that will fortunately be covered by warranty. I should have some more information later from them today or tomorrow.
SRobinson541
