Wi dow error
jimr5454
My 2016 Yukon Denali with 122,158 on her is asking to roll down and roll-up the driver's window then the passenger window .it's done it three times now ? And the power steering is randomly coming to a hard stop randomly usially when I'm turning in a parking lot not often probably 3 times and only for a split second.are the connected some how or do I have two issues .any help would be greatly appreciated
Fless
Super Moderator
Elev 5,280
Moved you here from the 2021+ General Discussion. Might want to fix that title. ;)
IIRC sometimes when a battery is changed, or is failing or a battery connection is compromised, the auto up/down window setting needs to be reset, and that's what I suspect is happening here.
jimr5454
jimr5454
Thank you .I will check the connections.
Jimmy17
Southern Idaho
Just spit-ballin' here, but you might wanna have a conversation with the service mgr at your GM dealership. It MAY be program related and simply require any updates; or possibly a reboot. Other than that - a gallon of gas and a book of matches fixes just about everything electronic or mechanical that I can think of.....
