Z71 vs RST suspension height
suterusu
Does air ride add additional height?
Yes, not base ride height, but air ride does allow you to raise I believe 1.5" above base ride height via the controls to the left of the steering wheel.
WVBKW
The driver control system enables four different ride heights to be selected. The selected mode is shown on the Driver Information Center. (Fig. 14)
Entry/Exit Ground Clearance – Lowers the vehicle for entry and exit.
Normal Ground Clearance – Standard vehicle height for normal driving
Increased Ground Clearance – Raises the vehicle 1 inch (25 mm) from Normal (4WD HI)
Maximum Ground Clearance – Raises the vehicle 2 inches (51 mm) from Normal (4WD LO)
Adjustment is 4 inches from lowest to highest.
More INFO HERE:
Tinbadtin
My bad, I thought Z71 came standard with air but I stand corrected - only if off road package is selected. Also the 1.5 inch increased ride height is something I remember from the initial reviews on TFL truck but that seems not to be the case either.
cervantesjesus174
