93BlkOnGreenPro's 2007 Yukon SLT Build Thread
Added ds rear manifold clamp. That was a *****. 3 hrs. 2 bolts. Uncounted curse words. Quite a few made up.
Did the plugs and wires as well.
Added a longer ground since the one ground is now too short since i stole the hole it was in. Moved it to the front of the head.
Intake manifold is next.
What's up with the intake manifold?
93blkongreenpro
93blkongreenpro
Broke the nipple where the pvc hose goes too when doing the catch can. Moroso's instructions says to twist it out. It's a non service part. So the entire manifold has to be replaced.
Oh crap. Thanks, Moroso.
93blkongreenpro
93blkongreenpro
Sent my interior pieces to BE Motorsports in Pennsylvania to be hydrodipped in Black Walnut. I was going to paint the glow black, but figure with my shortage of free time and the fact that I did not finish vinyl wrapping them, I should probably outsource this job. This is his first time doing interior pieces, so hopefully it comes out awesome! I will post results as I should get them back next week.
I am ready to get them back! Been riding around with a partial interior!
Fosscore
Figured I'd ask since you just took these out. Were all your trim pieces just snap in and out?
93blkongreenpro
93blkongreenpro
They snap out. But the little vent piece had to be drilled out. But I will prob put a little rtv on it. I'm not sure how critical it is for no gappage between the pieces.
Fosscore
Thx man. They are just the standard GM push clips? With that being said, is there any best angle or side to start with for the pieces and how did you lift the first bit to start to remove it?
93blkongreenpro
93blkongreenpro
Standard clips. I a plastic panel popper thing and I start at the radio. The middle air vents connects all the way to the passenger vent. FYI, the passenger vent is not connected to the piece above the glove box.
kwOH
Banned
Are you leaving the actual part around the vents the brushed silver? Like your steering wheel spokes?
Sent from iPhone 7 plus using Tapatalk Pro
Ja1034
