2013 SSV seats
Ron C
Los Alamos, NM
Hello,
when I was installing the center console I noticed a 'black box' underneath the seats, they look very similar to a "memory seat module" I have seen on the web. I doubt that's what it is though, or did SSVs come with these? (and if so, how do they work?)
Also, does anyone here know the part numbers for the trim pieces (front passenger seat) that go on the rail ends? (inside goes on the rail end, outside is a small 'panel'
Ron C
Ron C
Los Alamos, NM
Hello,
well, one of them is called a 'bolt cover', who knew, the GM part number is 15214533 (it's the flat cover for the outside, front seats)
Lightning 95
I found a cover in my 13 P, and haven't seen where it goes yet. GM 15128779
Ron C
Ron C
Los Alamos, NM
Just 'googled' it, that part seems to be from the passenger seat, the "inboard" "bolt/rails" cover, the hole underneath goes over the nut/stud (you kinda have to twist it in, it doesn't really take any force)
I need the one that is at the other end of the same track/rails.
Ron C
Ron C
Los Alamos, NM
lightning 95: funny thing, I was on ebay looking for a pic with your part number and it also showed the part I was looking for (in a way too expensive trim kit). I could zoom in and see the part number. ... anyway, the part number I was looking for is: GM part 15128778 ... a lot easier to find once you know the right number.
thanks!
NipRing
