Help fixing separating armrest in 2001 z71
mattbta
Frisco, TX
The underside of my driver door armrest is doing the same (2004) and am interested if anyone has a solution. I don't even know how I could clamp that rubber down for an adhesive to cure. And IIRC, they don't make the parts anymore.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
With luck we will figure something out :) anyone have experience with this?
Jeffro41
I am having the same issue on my 2004 Tahoe on front passenger door.
My idea is to use a high temp adhesive to reattach the armrest. I just need to figure out a way to hold it in place while it cures. Maybe tape???
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
High temp adhesive as in hot glue? Or something else? I tried hot glue and tape... the tape wouldnt hold it long enough for hot glue to cure. I thought however i should use bar clamps instead. But really got impression hot glue wasnt strong enough.
well if your going to use glue, use gorilla glue that stuff is true to it's word but be aware it likes to "expand" not in size but as in coverage, use sparingly. it will seep out any hole or crevice and you will need to keep wiping it off until it sets, once it dries it's super tough though it holds it's bond. just an idea to try
and yes you will need to clamp whatever it is until it is fully cured, it's not super tacky at all.
I think small bar clamps would work well, along with some small pieces of wood to help it along. Hot glue won't work well. Once it dries, it gets hard, and it'll look and feel like $hit. You could also try the Goop adhesive. That stuff is amazing!
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I like the gorilla glue idea. I thought i may need to scrape away a bit of thr foam underneath to make way for a strong bond. I may try this. Thx for the idea... how does it c9mepare to jb weld?
Timqua
