St. Louis
Changed the spark plugs and wires.
It was harder to get the spark plug cables off then it was to remove and install the plugs.
Hope I torqued them to the correct spec, 11 ft lbs if I remember correctly
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
2001 Yukon SLT
St. Louis
Sweet, I remembered correctly!
Did them all from the top. Driver's side super easy, passenger side not so much due to having to work around all the AC/Heater hoses and dipstick.
Like I said above, took longer to pull the wire off the plug then it did to remove/install the plug...lol
I used to have plug wire boot pullers that looked like a pair of pliers with rubber coated right angle ends, but I couldn't find them so just did them all by hand.
R3cord303
Posse In Effect
Oregon Valley
Used the tahoe to get another load of belongings from the old place to the new. Raining decently here. Turned off stabilitrack and slid around a corner little bit. Its amazing how differently it behaves with the nanny turned off.
New tires are ordered and will be installed this week as well!
Burb!!
Biloxi, MS
My key was starting to look like trash and I got a Chevy blank from Amazon; home depot cut a copy for me for free and I programmed the new transponder chip key to the truck. Spent about $15 in total.
R3cord303
Posse In Effect
Oregon Valley
Whats the part number for the 2015+ fob?
PG01
Up here to the right
Throw up a pic of that big ol bish...i miss seeing it
AMM1986
