St. Louis
So titanium exhaust is lighter than SS and has a different tone/zing to it, but at a lot higher price tag.
How much weight savings over a SS exhaust, 5-10lbs? I'd rather spend the money on hookers and blow. The blow will help me lose the weight and the hookers would be greater enjoyment.... Lol
GO CARDS! NLDS CHAMPS
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
R3cord303
Posse In Effect
Oregon Valley
2001 Yukon SLT
For the same amount of tubing, its 40% lighter, and demonstrates a higher level of skill to fab with it.
My cats are toast for the third time, so I just ordered a set of these and an off-road Y-pipe from TSP. They should be here in time to install this weekend.
I'm also going to finally swap out my plugs for colder ones to run a 100-150 shot. The bottle has been empty for a while, because a 50 shot isn't noticeable enough to be worth it. My 4L60 is gonna love me.
I was about to say that you need to fix your running issue that's killing your cats or stop buying cheap cats, then I glanced over at your avatar and was like "Ooooooohhh... It's that guy."
So, who are you considering for a built trans?
R3cord303
Posse In Effect
Oregon Valley
If you really want to go all out, use inconel. You can't beat it for strength and corrosion resistance at high temperatures. Save the titanium for the exhaust tip.
Inconel is my favorite metal. But I don't know where to buy it from and I don't know if you can tig weld it. I know SpaceX uses it in their SX300 and SX500 alloys for the Raptors. I've also seen it used for Lambo cat delete pipes.
the_tool_man
Upstate South Carolina
It TIG welds similarly to stainless. Different filler rod, of course.
claymaloy
