DaRosa218
The Dude abides
Modesto, California
Wow, she looks great Mike! You don't happen to have a Tech-2 or something similar do you??
Thanks Buddy, I take a lot of pride in that Yukon.
I have a FOXWELL NT510, it can do a lot of features but not everything the Tech 2 can. I wish it would let me program the dang navigation radio that I just scored at the local junk yard! Scored a Navi out of a 2012 Denali for $100 yesterday, but it is Vin locked
PPV12HOE
NC
Nice steal...
I couldn't believe when they said $100 for it. I already have the UQA package from the factory so it should be plug and play with the vin relearn to unlock it. Fingers crossed!
Greg at CPS in Cotati can hook you up if you don't have anywhere closer to you.
BG1988
you can take it to a dealer they do it for free* just gotta prove it's yours
*some dealers may charge you for the code
How to Unlock The Radio in a Chevy Car?
  1. Step 1: Start your car and turn the radio on.
  2. Step 2: Press and hold the preset numbers two and three till a code with three digits shows up on the display of the radio. ...
  3. Step 3: Press the FM/AM button. ...
  4. Step 4: Call the phone line of the Chevy Radio Code at 1-800-537-5140.
  5. After that, enter the following numbers 1-0-6-0-1-0 and the #
R3cord303
Posse In Effect
Oregon Valley
I got the rear spacers installed, drive around the cut-de-sac and then retorqued the lugs. I came inside and did some googling whilst eating dinner, and the GM half ton stuff apparently, runs about half an inch narrower in the back vs the 3/4 ton and 1 ton stuff runs about 1.5 or 2 inches narrower in the back depending on who you ask. I’m glad I bought both the 1/4” spacers in the back and the 1/8” spacers in front because I do want the front end wider.
What he needs performed is different than the unlocking code. The HUs are programmed with the VIN of the vehicle they're installed in and won't work if they detect a VIN from another vehicle. He needs the HU he got from the Denali unlocked so when he installs it in his Yukon, it'll accept and lock itself to his Yukon's VIN the first time it's powered up.
Tssonebay
