2005 Yukon cluster LED conversion question
Onebad1983
Resident Country Dumbass
Has anyone used superbrightleds.com to replace their cluster bulbs? If so on the quantity selection do I just leave it at one to get all the bulbs I need or is it talking about one bulb per qty?
Bombsquad85
Northern VA
For an 05 I used LED strips.
If you use individual LEDs you'll get hotspots. I placed the led strips around the bezel and I hsv uniform lighting all around.
The one with the CEL is the LED strip . You can see the difference
It's actually easier to use the led strips too. Instead of soldering each individual bulb you just need to solder the wires for the strips. I did the strips over 2 years ago and 0 issues so far (did them April 11, 2018 according to the time stamp on the photo)
Onebad1983
Onebad1983
View attachment 245680 View attachment 245682
I was worried to know if these were solder in or screw in like the 00-02 cluster. I can solder but I haven't practiced with hot wires (I know to disconnect the battery, but still)
NathanJax
Vacation Nathan
Administrator
Jax, Fl
great website, 100% recommend.
Same as these guys say, 03-06 are LED's instead of 194 bulbs like the 00-02. Depending on the LED's you use, you could get hotspots...
Onebad1983
Onebad1983
Do you know if these LEDs would cause hotspots? And how long they would last? Also are their high/low beam bulbs worth the money? I'm using cheap eBay ones currently and I'm on my second set in 3 months
NathanJax
Vacation Nathan
Administrator
Jax, Fl
I don't. I never swapped LED's in my 03, just in the 01
I took @Rocket Man advice and just installed these LED's in my Silverado. Obviously haven't driven at night yet, but maybe he has and can give feedback.
https://www.amazon.com/gp/product/B07NPMV1H5/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
UPSdriver
