Tires
massivespl
I'm not mean, I'm honest.
Michigan
If your only getting 20-30k miles out of your tires there’s something wrong. Almost everyone gets 50k+ miles unless you haul trailers all the time and really put those tires to work. Michelin tires are good all the way down to the wear bars. So if you replace them early your wasting money.
What I do is buy tires. Use them 1-2seasons and then sell the tires for half price and buy new tires. I get brand new tires and only have to spend half the money as long as I sell my old tires
sealandsky
Minneapolis, MN
I also agree Michelin's are not what they are hyped up to be. They are probably a decent tire but not for the increased price. They seem to handle the road and weather well but I have yet to have a set that lasted. I never got more than 20k miles on a set, which doesn't work for me. 2 sets on the wifes car, replaced under tread life warranty and another on a SUV I had. Or I'm just unlucky....which is also possible.
The Michelin Defender and especially the Premier have a pretty soft compound. Soft = better traction and ride = shorter life. Anyone buying these tires should understand this. I'll be buying a set of Premiers soon and accept the fact that they won't last me a full two years.
B
busterw
The Alenza is just a horrible tire. I think I got 25k miles out of mine and they were totally shot. Plus, the wet traction is pathetic at best.
My Bridgestone Alenza's just turned over 18K miles and won't make 20K.
Danny3737
You are 100% correct. The softer the compound, the quieter and smoother the ride. My number one reason for buying them for all my cars ( especially my kids ) is a softer compound equates to a shorter stopping distance, especially in bad weather. You can’t put a price on safety. I’ve never had a set go less than 40K miles.
wjburken
Eastern Iowa
Man, I just don't get it. I believe every one of you guys with what you are saying you are getting for wear out of your tires, but something doesn't make sense that there would be such a wide disparity in this area. As an engineer, this is driving me nuts as I believe there has to be something we are missing that is causing these differing outcomes. My personal experience is that the Bridgestone Dueler Alenza H/L's give me 85K+ of wear. I also read here where folks are getting similar wear out of their Michelin Defenders. That is why I am just baffled when I also read that folks are only getting 20K to 30K of wear out of what is supposedly the same tire. So I did some looking. Tire Rack has a few different options for tires shown for my 2013 Denali XL with the H/L Alenza name with different Load, Speed, Treadwear, Traction and Treadwear ratings. I wonder if this is contributing to the different experiences of folks because folks all have Alenza's but different performance ratings.
Dueler H/L Alenza Plus - 111H - UTQG: 800 A A - ECO-Product (whatever that means)
Dueler H/L Alenza - 111H - UTQG: 600 A B
Dueler H/L Alenza - 111S - UTQG: 700 B B (what I have been buying and is listed as OEM)
Dueler H/L Alenza - 113T - UTQG: 600 A A
Here is the link to what I ordered the last two times and what was on my 2013 when we bought it in July of 2019.
https://www.tirerack.com/tires/tire...eModel=Dueler+H/L+Alenza&partnum=755SR0HLALNZ
For Michelin this is what I found for the LTX line of tires shown on Tire Rack for my 2013 Denali XL
LTX A/T 2 - 113T - UTQG: 500 A B
Defender LTX M/S - 113T - UTQG: 800 A A
LTX M/S2 - 113H - UTQG: 720 A A - Green X (whatever that means)
I know that I may push the life a little so instead of 85K, maybe I should say I get 75K+ of good thread life and then another 10K of life because I might push it a little.
My wife also does most of the driving and her commute is mainly highway so that may contribute to out experiences. She is also not an aggressive driver, usually.
I rotate the tires every other oil change (7000-8000 miles) and maintain the tire pressure regularly. Not saying others don't, just explaining what is happening on our vehicle.
Like I said, there has to be something that can explain the different experiences folks are having.
B
busterw
Well the Defender is supposedly a longer lasting tire than the Premier. The Premier is my current set that I'm replacing with the Defender LTX M/S. The Premiers I got 30k miles out of. I rotate tires every oil change and maintain 38psi of pressure all around. Now, I will admit that I don't drive like my grandma so I will attribute some lower mileage to my driving style. Also, my driving is about 50/50 around town and highway which will also contribute to a lower mileage.
https://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Dueler+H/L+Alenza&partnum=755SR0HLALNZ
Seen lots of folks denigrate their tires when their alignment being out of whack was the culprit. Failure to rotate and keep them properly inflated kills them quicker too. Properly inflated to them means keeping the light off on the dash, not actually keeping them at proper setting.
drakon543
proper tire inflation driving habits and condition of the vehicle including proper alignment all play a factor. if you have one person who drives it like they stole it most of the time your going to see serious differences in tread life. regardless if the op is seeing a significant lack of tread life first he should have the vehicle checked over for any problems. if there's no problems there maybe a change in driving habits could help. you dont have to be doing smokey burnouts to be losing tread life.
BlackYukon
I'm kind of a Retard
Like others have said, there's allot of factors that go into getting the life out of your tires. I'v got around 20k Miles on my current set of Nitto's and they still have at least another 40-45K of life left.
I rotate them every 5K miles, make sure they are inflated to the right psi once a month, and get my alignment checked once a year. Kind of a basic system that doesn't require much work, but it has always worked for me in terms of getting the life out of tires.
Zredleg
