Front and Rear differential fluid change ??
RobDenali
Indiana
Can anyone confirm that when changing your drive train fluids, do you fill until it starts to come out of the fill plug? I am horrible at measuring liquids
Thanks
wjburken
Eastern Iowa
Thanks
Make sure on the front differential that you can get the fill plug out before you pull the drain plug. Otherwise you could end up with an empty differential and no easy way to refill it.
Hollys Denali 805
