Robslost
Wilmington NC
Hat tip to @95escahoe , I finally figured out what the two mystery buttons are in theothertwin. It has a secure-idle unit installed, and it works!
View attachment 273355 View attachment 273356
Routing wiring for my dashcam and radar detector a while back and found a foot pressure switch under the floor pad.
Did some searching and found out it was this...
https://www.tremcoemergencyproducts.com/anti-theft-system/
Shift lock pressure switch.
Sam Harris
Yesterday, I capped off the cutout half of my exhaust since the valve fell apart. Now it's just running through the 40" of muffler and the 3" unmuffled part is acting like a Hemholtz chamber.
Beat a piece of cardboard on the tip to get a pattern:
Cut out the pattern, traced it on some 14 gauge sheet and cut it out:
Welded, primed and sprayed with high-temp paint:
It sounds LAME. But, it's really quiet inside. It's only slightly louder than when I had the 18" muffler and cats. Of course, at WOT and high RPM, it gets louder than it did back then. But at no point is it uncomfortably loud any more.
Nice work. I’ll bet it sounds hellova lot better than when that valve was falling apart!
Sparksalot
Bastrop County, Texas
89Suburban
Bull in the china shop
SE PA
Very nice welding work there brother.
Thank you.
It's really screwing with me, to be honest. It idles and lopes like it did before, but now that it's so quiet, it's like a stock vehicle with a misfire. The flapper fell out a month or so ago so it was always either 50/50 muffled and unmuffled (loud) or, with the cutout open, muffled side closed off and unmuffled side 100% open (loudER).
I'm just glad to be able to cruise and converse with the fam again. I'll probably have to design and make my own cutout to have what I want. I have many, much larger priorities at the moment.
St. Louis
Our vehicles already have this ability, called "Immobilizer" and just needs a switch providing 12v to the tan/white wire from the BCM to the shift lock solenoid.
Sam Harris
Yes, I suppose all you really need is a button to activate / deactivate it... [emoji3166]
No more cutout then? NVM, caught up in the thread.
Thank you.
Reminds me of my Silverado with it’s too quiet exhaust and the cam makes it lope hard. It just doesn’t seem right. Damn truck rocks a bit from the lope but it sounds weird.
BKraft
