2002 5.3 intake manifold gasket replacement.
R422b
Oklahoma
I need to replace the intake manifold gasket on my flex fuel 5.3 Tahoe and I was wondering if there is anything in particular I should know about?
I did a forum search but I couldn't find anything.
Sent from my moto g(7) play using Tapatalk
R
R422b
Oklahoma
I hear of people putting rtv or various gasket sealers around the openings in the gasket so I was wondering what everyone's opinion on that is.
Livebai8
Houston, Texas
I did the same for my 02...i did so because I had to replace the knock sensors so I changed the sensors...new pigtail, and them went ahead and did intake gasket. I also cleaned the inside of intake, and cleaned all the fuel injectors. It's one of those times where if you open it up replace everything. The only thing i didn't do was the oil sensor.
02 TAHOE LS 4X4
5.3l FLEX FUEL
285/70/17 W/Z71 RIMS
Sent from my SAMSUNG NOTE 5 using Tapatalk
R
R422b
Oklahoma
02 TAHOE LS 4X4
5.3l FLEX FUEL
Good idea. I will definitely clean everything.
Livebai8
Houston, Texas
It was my first time so I took pics, notes and even printed out the torque sequence!!
02 TAHOE LS 4X4
5.3l FLEX FUEL
Sam Harris
You also want to build up a small dam of rtv around those knock sensors. They have an issue with corrosion getting down into the sensor holes, so it’s a good idea to stop that next time around. Like so:
R
R422b
Oklahoma
I wonder if I should replace the knock sensors while I am in there?
bjwaller
