dwinters14
- Joined
- Apr 10, 2020
- Posts
- 86
- Reaction score
- 61
Hey all,
My a/c isn't working and I need help narrowing it down. My trucks heat and a/c both weren't working, which ended up being a bad door actuator. I replaced that, reset the HVAC controller and the heat was working, but not the A/C. My rad blew up and I took it to a shop to fix. They said my A/c was low on free-on and put in 3 lbs. The a/c worked and was cold.
Fast forward to it being summer and it's hot out. I go to turn on my a/c and no cool air, in the evening i tried my heat, and again ambient air. So i reprogrammed the controller again, and my heat is working again, but no a/c. A friend of mine and I hooked up the a/c gauges and found pressure, I'm just not sure how much. The compressor kicked on, as well as the fans, but again no a/c.
I think there's a leak, but everything I'm reading about online is saying I have to take it to shop so they can use that expensive machine.
