"Hot" Side Unboxing - Twin Turbo Install
RThomasII
So after a bunch of debating back and forth between various forced induction options, I finally decided to pull the trigger on the Armageddon Twin Turbo System for the Caddy. The "Hot" side just arrived. Still waiting on the Turbos and "cold" side to be delivered. Will be dropping everything off at the coaters on Monday to get the hot side ceramic coated. Hopefully that will keep the under hood temps down a bit.
I also plan to update this thread as progress continues. Kinda boring right now I know but I'm super excited to FINALLY get this project off the ground.
Any questions.... Feel free to ask....
Looking forward to reading your update posts on this project.
BlackYukon
I'm kind of a Retard
So after a bunch of debating back a forth between various forced induction options, I finally decided to pull the trigger on the Armageddon Twin Turbo System for the Caddy. The "Hot" side just arrived. Still waiting on the Turbos and "cold" side to be delivered. Will be dropping everything off at the coaters on Monday to get the hot side ceramic coated. Hopefully that will keep the under hood temps down a bit.
What made you go with turbos over a supercharger? No hate, just curious since I plan on getting some kind of forced induction in the near future.
RThomasII
RThomasII
I spent a lot of time doing research, watching YT videos, etc. 1st. The Armageddon kit seems to be made up with high quality parts. 2nd. Without getting all techie, the system seems to make pretty decent WHP and torque numbers on low boost. I've got a certain HP number in mind and after talking it over with my tuner I'm hopeful we can get there while still leaving power on the table in a effort to keep everything safe.
The other thing is... Honestly... I didn't really have a plan going into mods with the Escalade so I've burned up a lot of time and money trying to get situated the way I want. Using the Esky experience as a "lesson learned", I actually have a future project in the works that I'll probably end up supercharging so it came down to deciding to do something different with the Caddy. Plus the turbo options for the future project didn't look as high quality as the Armageddon kit. If that makes sense.
Last thing is I kept hearing Whipple was launching a Gen V 3.0 for the '15 to '20 but it doesn't seem like it was coming anytime soon so I just went this route.
BlackYukon
That makes sense. I plan on waiting for the Magnuson/Whipple 3.0 to come out but I'v been keeping my options open. Looking forward to your progress on this build.
CMoore711
The Armageddon kits are nice. They have really good symmetry and dare I say look about as “OEM” as an aftermarket turbo kit could look. They do consist of high quality components and you can tell they put the R&D into their hot and cold side pipe routing and plumbing.
For me I’m just torn on the power delivery to weight ratio of our SUVs. It just seems that immediate torque from a supercharger would suit our heavier rigs better than the spool of a turbo set-up. That being said, turbos are more efficient and have a much higher ceiling of power potential.
I’ll be following this thread for sure. Very interested to see what boost and power levels you can achieve on the stock block/internals. In addition to usable power on the street for day to day use.
Congrats on pulling the trigger. Cheers to a smooth install and tune experience!
gat0r
DFW
can always add the whipple Gen V 3.0 to the armageddon kit later ;) :headbang:
RThomasII
RThomasII
Just a quick update....
Picking the headers and downpipes up from the ceramic coaters today. I just went with satin black... Nothing special there. Also, Armageddon shipped the remainder of the kit on a pallet over the weekend. Assuming everything arrives on time, I should be dropping off to the installer on September 27th. Delays in part availability at Armageddon and my daughters graduation from Naval Station Great Lakes boot camp this past weekend pushed out my timeline a bit.
Now I just need to figure out gauges and a gauge pod to mount everything up and still look somewhat oem. Thinking TurboSmart and Aeroforce but still undecided at the moment.
CMoore711
You're less than a week away from install!
Really looking forward to hearing your feedback on the day to day drivability and how much power you end up with. It's going to be a whole new truck.
Curious to see how the kit fits out of the box or if there are any items that have to be adjusted or changed in order to complete the install.
Sounds like you're dropping it off at a local performance shop for the installation; Assuming this isn't their first rodeo installing boost onto GM LT/LS platforms...
How familiar are they with the Armageddon Turbo kits? Have they installed any of them before?
Is Armageddon providing your installer/tuner with a "starter" tune file or is the shop going to install and tune it themselves?
Did Armageddon make any recommendations as to the max amount of boost you should run on a stock 6.2 L86 and stock 10 speed transmission?
You mention in the first post you've had conversation with your tuner; Have they given you any maximum recommendations for boost pressure?
Your motor is all stock right? As well as your 10 speed transmission?
Curious to see how well the 10 speed holds up to the extra power and maintains daily drivability. Has your tuner mentioned anything about the trans tune or recommended % of torque management to keep the trans alive?
Sorry for all the questions. Just not too many people throwing twin turbos on the K2XX SUV's!
Jongrreat
