2021 22" Cadillac Escalade wheels on a 2021 Yukon Denali
yeti003
Hi, I currently have 20" polished aluminum 6 spoke wheels that came stock on my 2021 Yukon Denali. I've been watching for some black rims and came across a set of 22" rims taken off of a 2021 Escalade (22" Wheels, 12-Spoke Gloss Black - GM (84586634)). I wouldn't think there would be any fitment issues but would appreciate any feedback from the forum. I wouldn't have posted except the GM accessories website indicates that these won't fit my Yukon.
ljn21
Not an expert but 99% sure they should work.
adventurenali92
Big Bear Lake, ca
They will work. Bolt pattern is exactly the same. The only thing that may provide an issue is the wheel offsets of the two setups. Get the specs for both wheel offsets. If the specs are within a few millimeters it won’t be an issue. But most of the factory GM Wheels are pretty close in offset so it shouldn’t be an issue.
^^^x3 As recommended above, get the specs for the 2 wheels, and see what differences, if any, exist between the two for rim width and offset.
Dustindu4
Salem, NH
Also GMC has smoking deals on wheel packages. 25% off
I got the new black 22s for 2800 with tires delivered. That's mounted with sensors and nuts. Rims by themselves were 1650. That's what knock offs go for and you don't need spacers
Stbentoak
I wouldn't pay 1150.00 for Alenza's.... I'd sink that money in a good set of Michelin Defenders and you would have a far superior tire....For just a little more money....
Martin D
I replaced my 6 lug 17" with Escalade 22". Took 2 days to adjust to new feel otherwise no problems.
Y
yeti003
Thank you all for the replies - I was able to find all the specs and they would have been perfect but unfortunately someone bought them before I was able to. I'll be watching for another set.
whittlc
