alpha_omega
Michigan
And here i am looking at a fluid transfer tool that eric o from southmain auto was using on a recent video.
moved gear oil into a diff, it was so smooth it has me going Hmmm... lol
Ha! You watched his front diff video didn’t you? I saw that transfer pump and thought the same thing that you did.
*edit - Make sure to get some denatured alcohol for cleaning the hoses. I use it on my other fluid transfer pumps and it sure beats using soapy water or ruining something with brake cleaner.
I’d like to know what the p/n was on that stubby air ratchet he was using. Sure beats the old style or any with a longer nose/bit attached to the end of it.
alpha_omega
Michigan
I installed new valve covers and put 75lbs flex fuel fuel injectors in the maggy
Fancy pants! Look at those purdy things. Where did you pick up all that new gear from?
You’ll have to keep us posted on the new injectors, whether they are any better/worse than OEM.
Just Fishing
Can't fix stupid
Utah
I missed the air ratchet, but i have two stubbys from Astro.
1/4in (actually neiko but i can't see a difference between it and astro)
and most recently this 3/8in
Using their little stubby impact sockets, it seemed like the perfect mate for it
Adds a tiny bit of wobble + being tiny.
alpha_omega
Michigan
I have two air ratchets like that plus my Milwaukee M12’s (1/4 & 3/8 speed ratchet). The one he was using in that video had the power of a standard 1/2” air impact minus the “nose”.
alpha_omega
Michigan
Haven't decided yet! Putting the AC, supercharger, ICT Billet brackets with accessories in first! Possibly underneath, where AC Compressor was, or on backside on firewall.
I was wondering the same thing.
Are you not worried about the heat if you put them on the firewall, or were you thinking that if mounted high enough and heat wrapped that they should be ok?
Midnigh_D_Tahoe
