GM/Brembo Performance brakes - thoughts + pics
mikew2069
Reporting back, yep, absolutely more brake dust.
I've personally never worried about brake dust, sometimes superior results require a little more work.
Thanks for the report... Yea, I mean its basically science. Not much you can do about it.
91RS
GA
They do make more dust than stock; however, these don't have super aggressive pads like say a CTS-V or Camaro. My SS 6 pistons make significantly more dust than the ones on my truck.
DenaliCountry
I have the Big Brake package on my 2015 Denali. Word of warning. No one told me this when I ordered them or after having them installed. Your spare tire will not fit Over the Brembos . GM answer, (I found out the hard way! ) is to do a 2 tire change if the flat is in the front. So they even put out a service notice. Swap out the rear tire 1st with spare and take back tire to replace the front flat. I tried putting a 20in spare underneath but won’t fit as it’s molded for an 18. 20in is the smallest rim to fit over them. If I had known this not sure if I would have gotten them. Just a word of warning!
Same with the Jeep GC SRT. I never had a flat on mine but if I had one on the front I would have had to do the same thing.
MBTahoe
I wanted to post something positive after not liking the GM perf. exhaust, overrated and a pass imo.
The Brembo brakes on the other hand, BUY them if you like pedal feel or are coming from a German car. I feel everything they quote in the release - 42% larger, 16.1 rotors, 84 percent increase in brake pad area, 31 percent reduction in pedal force and 12 percent reduction in pedal. Imo, well worth the money.
For me, I felt the stock brake pedal was mushy, especially on hard braking - how hard do I need to push to get some feedback or get it to stop? They never gave me confidence.
When bedding the rotors/pads today, they actually overpowered the tires and locked them up a little which is the feeling I would prefer. The stock brakes could never overpower the tires which is sad because the tires are made for a mileage goal and road noise (imo), thus not the stickiest compound available. The downside to the brakes, now I want to show them off and look for a new tire/wheel combo. Very happy with this addition. Yes, they are expensive but it is something I felt the first time I pressed the brake pedal.
Nice!! Did you buy the front ones only or both sets front and back?
Thrust
ICT
I picked up a used 5JL kit today. Has anyone used Stoptech SS lines with them?
CMoore711
No experience with the Stoptech SS brake lines, but I’m sure they’re fine. Wilwood also makes a SS Brake line kit.
In my experience SS brake lines can really have a positive impact on pedal feel and brake response. Even when added to stock brakes.
Thrust
ICT
I ordered some Stoptech SS lines. Once those get in I'll work on the install.
O
Oaktree
Both BUT one of the rears had a chip in the electronic brake module. I need to go back for install on those.
YukonFromTheGrave
Coral Springs, Fl
I definitely recommend the Brembo upgrade. Much smoother and doesn't feel like its struggling to stop the vehicle in any means. They look great and gives the vehicle a whole new look. There is a tad bit more brake dust but nothing to complain about. Worth every penny!
Snefferz
