Lifted/Leveled 2021 - Postem Up
nick14226
None at all, I will say the distance between the upper control arm and the tire leaves some to be desired! But it can go lock to lock and doesn’t hit anywhere
Looks great!
Are you pretty level with the 1" up front? Feel like mine is near level at stock height so any lift in the front would need to be matched in the back or I'd be nose high.
GThomasD82
Looks great!
It honestly depends on the angle but generally sitting in a parking lot it’s level. You can see what I mean in these photos, one photo it’s level the other it looks a little squatted
MFCOffroad
Do you have any pictures of the trimming needed to accomplish this tire size setup? Anything would really help. Also what offset/backspacing are those methods?
JerseySUP
Looks great!
I’m 100% you. I feel like my Tahoe is completely level from the factory. I want to incorporate a modest lift (1” - 2”) but I’m nervous to go with most kits that are available right now, since they all tend to raise the front more than the rear. If I could find a 1.5” lift front and rear I feel like I’d be happy.
JayySalas
