St. Louis
Finished, added about 2.5qts of fluid and all buttoned up and everything torqued to spec. That damn trackbar was a bit of a ***** to get the mounting holes lined up. It was very tight in the brackets. I did grease the bushings before trying. After a few cuss words and laying there contemplating the situation and what I had to work with I was able to use a big pry bar in certain locations to get it all lined up.
89Suburban
Bull in the china shop
SE PA
Looks great man!!! Nice job!
YEP
Just got done looking at my passenger mirror motor. I pulled off the back cover and checked the wiring. When the fold button is pressed the mirror does nothing. No noise, no vibration, nothing. I pulled the plug going to the motor and connected a DVM to the 2 leads and set it to DC voltage. It was in auto mode and was reading very slight mV, but when I pressed the fold button the voltage would jump up into the 12v range for a second then go back down. So guessing it's a bad motor and not gear related.
I have to research what my options are here.
you could maybe find a used oem mirror on ebay a scratched up or damaged one and use it for parts
I think I used that same bolt kit. Looks great.
PG01
Up here to the right
Did the trans lines today, replaced the cooler too because why not…never and I mean never doing those lines again rotted right where GM put the little piece of plasticy wire loom crap to protect it from the diff or frame or whatever but it just made it rot out because of…. Northeast… (use your imagination) fell apart in my hands…. Cut that shit off the new line set…. What a pain in the d I c K … face full of rust and dirt …. Fun fun
Pic because….ya know
Glad to see you turn wrenches again Pete!
Charlie207
LFOD, New Hampshire
Is yours 4x4?
Did you have to remove the cross-member to get those trans-cooler lines out? I spent a couple hours trying to get the old ones out, but couldn't wiggle them free.
Also, got a face full of rusty dirt, or was it dirty rust?
Tinkerer4
