Door Hinge Pins and Bushings???
GMT800 SUV/Trucks
Military
If all 3 trucks take same kit, then go for it but likely need kits specific to each year, make and model. Also, door support is important for success and check ALL hinge mount spots for weld or crack problems. Also, make sure the bushing mount holes are not wallowed out.
E
Eman85
3 trucks, 98 K2500, 97 Tahoe and 99 Yukon. I believe all use the same kit, I'll check before ordering and I'll only order 1 kit.
E
Eman85
Here's an update, I bought the GM kit that I linked. Save your money and just buy a good set of pins and bushings. Kit works but it's poorly engineered. The bushings are nice and press right in. The pins are stainless and screw together in the middle. They are hard to screw together and the grease fitting deal doesn't work well. When you pump grease in it's supposed to flow through the pin to the bushings. It flows through the pin but comes out at the bushing with the least pressure on it. Obviously not the bushing that is going to wear the fastest and need the grease the most.
E
Eman85
I'd have to figure out how to post pics, do you have to host them to get them on here? If you go to the Amazon link there's a review with pics.
GMT800 SUV/Trucks
Military
It's pretty easy really. When you are typing a post, at the top of that window, to the left of the smilie face, there is a pic frame that you just tap on and follow the prompts. Hell, I am a BOOMER and I figured it out.
E
Eman85
Here's the pics, this site is easy many sites you have to host to photobucket or another site and then download from there. I'm a retired boomer too.
GMT800 SUV/Trucks
Military
Looks like the kit comes from the UK or around there. They spell "center" with the e at the end "centere".
bobbywdatool
