USB-C Upgrade?
THarber
Yes they come out often with the cord but no big deal. I haven't noticed them gettin ghot. I have one in cig lighter and one in the console.
RagingApe
So it didn't look like we were going to get an update so I bought the same plug OP has in his first post.
I have a 2016 Tahoe LTZ, and that plug is much larger and will not fit into either spot for the plug in front of the cupholders or the spot inside the center console. In addition to that, the 6 pin connector is not the same. The mini USB connection is correct for the center console spot.
In my Tahoe, the front spot is just 2 USB ports. The center console is 2 USB ports and an aux jack. I have an SD card slot in the back of the center console (RSE area), but that doesn't work for the radio at all... Only for RSE. I wanted to be able to load my music onto and SD card.
I ended up purchasing this P/N 13581213
This works perfectly and allows music from the SD card to be played through the radio. Has the same connections as the stock plug in the center console, and snaps right into place. Will update with pictures if I can remember.
Not the answer everyone was looking for as it doesn't add USB-C which would be nice.
K2 Kaiju
The Depths
Is there any advantage to this vs. just using the stock USB ports with an A to C cable? I have been using them for years without any issues...
RB_Trucker
Redondo Beach
I went and bought the original unit that the OP posted, I had the same issue with install with it being too big for the OG spot below the HVAC controls.
Blackcar
You can also use plug ins link in post #12 I use those and can just pull out if someone has usb cable etc,
if poke around ebay there are at least 3-5 variety of these in different configurations, one or another is bound to work
ElMasBuscado23
