Any amateur radio operators here?
Ghost10
Ghost10
Synchros
This is how my 2018 Yukon XL is configured. The mount is a Comet CV2ANTNCG (https://www.dxengineering.com/parts/cma-cv2antncg). I already had several of the Larsen NMO mounts. I do want to add a ground strap to the mount.
I have cut a few sections of clear PPF to protect the paint where the mount could potentially rub. Performance has been satisfactory. I'm too often traveling with a Yakima-branded photon torpedo on the roof to have a roof-mounted antenna, though I'd much prefer that. I do have power directly fed to the radio from the internal drivers-side fusebox.
Happy to answer any questions about it. 73!
iLikeEggs
Potato!
Oregon, USA
View attachment 387494View attachment 387495
I would power the radio directly from the battery. Its easy enough to snake through somewhere on the firewall. Just run your fuse in line. Sweet set up though!
GeroniMoe
South Shore, MA
Looks like you have that installed on the passenger side. All of the info I can find on that mount specifies it can "only" go on the driver side (which didn't make any sense to me) - any insight on that?
Thanks!
- Scott (W2EMT)
Synchros
Thanks!
- Scott (W2EMT)
Sorry for the delay!
I didn't want to put it so much in my field of view. It didn't seem out of the ordinary to put it where I did. It continues to operate just fine, in my experience. My VNA approves of it.
iLikeEggs
Potato!
Oregon, USA
I put mine on the drivers side mostly because of the shorter coax run. It's not that much shorter really but I don't see why it can't go on either side. Just personal preference. The fender is a better bet for a decent antenna though. Number one, you can get a fairly full sized dual band on there. (mine is an MFJ-1422). Number two, anything beyond a stubby on the roof will likely hit things. I have two NMO Mounts up top and had a 16" Tram up there. One day it took a hit in parking garage and slightly bent the roof a bit. That's when I went fender mount. Now I just have a stubby up top for GMRS.
Timqua
