George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
can't get this p0420 code to go away so ordered 4 new 02 sensors as a gamble just to see $177.00
if that doesn't fix it I will try and get the cat warranted but doubtfull, stupid thing is only 6 months old, the 02 sensors are about 5 years old with 75k on them.
something seems to be borderline the code will come up after 3-4 days right before it should be ready
When I had a bad cat I had the same symptoms. It took a while to run the monitor test, it would fail, and flag a code. That was on my NBS tho
I have had cat's go bad before but not in 6 months that's just crazy, getting close to time to do the 02's anyway so figured it might be worth a gamble
at least I can tell the shop that installed it that I tried everything.
RooTBeeRthe1st
That's a fun one to chase down
well it should simply be a bad cat, but if a 02 sensor is giving slightly incorrect information it could be a problem if anything it would likely be the downstream but I am not going to screw around and just try 1. If that doesn't work then at least I will not have to worry about the sensors for a good while again.
sensors should probably be here Monday I will put them in and reset the fuel trims and cross my finngers.
truck runs fine, I might even just have the code turned off and say screw it until it's time to have it smogged again, c.a.r.b cat's are not cheap right now
RooTBeeRthe1st
Even though I already have the actual physical flex fuel sensor, once I found out that it was likely my oxygen sensors causing the calculations for the ethanol content to be off prior to installing the sensor, I bought new sensors. And have had them for a long time and have not installed them yet.
So I'm wondering if even though the sensors I have in it now are relatively new. Only a few years, they were not OEM spec necessarily, so maybe these new sensors will fix that.
no idea, I know the ones in my 6.2 are heated and have had a rough 75k life, I have had luck before in the past just changing a 02 sensor for a cat code and it worked
jeffs2021
