blackelky
Good luck, MD and Northern VA construction zones sucked earlier this week! Fuel cost all the way down seemed similar to what you see on the NJ Turnpike!
I'm towing a trailer I'll be in the right lane going 60mph. For MD drivers the RIGHT lane is the slow lane the LEFT is the fast/passing lane. Oh and there are these things called turn signals.
Did u hvv o add the gm3 or 5 harness, to sync with pioneer and did u get the MRR2.
I would have to go back and "build it" again on there website.
that's what you need to do is go on there website and input all your information, it depends on the year/make/model, steering wheel buttons, oem radio type and aftermarket radio to be used.
Grady_Wilson
Wyoming
The foam from The Seat Shop is excellent - better than OEM in my opinion. And their replacement leather is also top notch. I used their seat foam but ended up getting the leather from eBay. That said, I'm pleasantly surprised by how well it's holding up.
Good to hear about the review on that leather.
I have used Katzkin leather on other cars and their stuff is fantastic, at least it was 22 years ago when I first installed one of their kits.
Seats still look great all these years and 250k miles later.
Zoni
I have 5 tires with sensors on both of mine. For the GMT900 it doesn't care which 4 are programmed. One of those could be the spare. If you have a flat it's going to just set a nag on the DIC.
It would be nice if GM would show all 5 sensors on the DIC. I had a flat, put on the spare (which doesn’t come with a TPS) so the DIC showed 0 on the DIC. Problem is that I then got into a snowstorm and found out the 4x4 didn’t work and there wasn’t a workaround. C’mon GM give me a work around!
j91z28d1
4wd didn't work while the spare was on.. ouch. don't get snow here but that seems like it would suck up north unless you had the awd system you can't turn off.
seems the only work around is to add a sensor to the spare and toss a programer in the glove box. reprogram the sensors. I've not done it on this truck yet, but my car it took like a min to walk around and beep each sensor with a 30$ tool.
Geotrash
Dave
Richmond, VA
I wasn’t aware that tpms sensors were required for the 4wd to work.
elianymanol
