Super Moderator
Elev 5,280
Installed a Hopkins Towing dual connector 7 blade/4 pin. Picked it up at Walmart for $15 (on clearance) and is a direct fit for GM vehicles. Took about 5 minutes.
I used the same #40920 on my '04, PnP. Works great and easy install!
blackelky
I always get them confused unless I go look it up..... lol
I recomend a shotgun approach, just bend over once and be done with it.
and use OEM
and oddly enough it's always this time of year when the weather changes that they crap out
just like batteries
That's exactly what I'm doing. Cry once buy once OEM because i hate doing shizz twice
mikez71
if you want to go that deep but make sure you have your fuel, maf and ve dialed in first, they are both part of the cylinder airmass calculation. so they can actually change the point on the timing table that the values are pulled from. so fuel changes can change the timing you're running. it's very weird, but just how gm did these newer os's
Nope! Just saw some changes in tune, figure it's usually an update or tweak. :p
Grady_Wilson
Wyoming
j91z28d1
well huh.. I guess I got a bad charcoal canister from rock auto. put the old one back on a while ago, just checked today and it passed its test.
guess I'm testing how you warranty stuff from ra for the first time and 6 months after I got it lol.
j91z28d1
ha.. so it's been so long I had forgotten it looks like I got it on one of their closeouts for cheaper. I didn't realize, not that it would have mattered because I wouldn't have expected a acdelco to be bad anyways, but there's no manufacturers warranty on it.
that's my luck lol. fixing stuff that isn't broken, score what I thought was a good deal. end up replacing extra parts troubleshooting with it. then in the end put the original parts back on, out like 200$ and still worried it's going to throw charcoal into the system at some point.
haha, gotta laugh.
Super Moderator
Elev 5,280
haha, gotta laugh.
You'd think there would be a good place in those canisters to install some kind of screen so the charcoal can't escape, no matter what.
j91z28d1
that would be nice.. I did shake the old one while it was out and could hear it in there. the new one I couldn't hear anything. makes me wonder how long it will last.
when I looked up the part number, this new one was what replaced the old number. but the manufacturer name was totally different. I'm still a bit baffled at what could leak on a new sealed box, no cracks or anything. I've never had one apart. so maybe a chamber inside?
since I have it. maybe I'll cut it open at some point and see what's in there.
blackelky
acdelco? The one I ordered says GM genuine on Rockauto. I wonder what the difference is.
Mrfirewolf1000
