2012 Yukon XL Denali - ignition power source
BSarteSr
I am putting a dash cam in my 2012 Yukon XL Denali and having trouble finding a 12VDC power source from the ignition? I had this in my 2007 Yukon and had it was working from a source where when I started it up the dash cam came on and when shut off the car off the dash cam also went off but having trouble finding a 12VDC power source near the fuses that I can use.
you can tap into the mirror harness 2 pink wires the center most 1 is the positive, black wire on the corner is the negative or in left side of the drivers footwell there is a small junction box with a black plastic cover, there are various connectors in there to tap into, you probably won't find a open spot because on the denali they are all used, but just use a meter and find one that is key on.
BSarteSr
BSarteSr
mikez71
Seems like a lot (all?) of the driver side fuses should be hot..?
Could also be the power adapter for your dashcam is set to only come on when voltage is higher?
BSarteSr
BSarteSr
Yes, they all are providing 12VDC all the time, can't find one that shuts off with the ignition. That is what I need, one that goes on when I turn the key on and goes off when I turn the key off.
mikez71
Okay, you want accessory or ignition power, I see that now..
Well. there is probably an easier way... (Doubeleive's mirror tap or the $30 ebay connnector!)
Worst case, there is some power at the left i/p junction block
underside
Ignition voltage might be better, 'Accessory' is highlighted only because that's how I searched for it.
BSarteSr
BSarteSr
Thanks, just what I needed, got it working the way I want.
I like using this plug, though it is $30 you could totally save, it also has a batt +, ground, and retained accessory power wire..
the only issue with this is on the denali (such as mine) all of the connections are occupied, no available slots. so I just pinned one of the connectors like I did on the mirror.
then I pinned the courtesy light to the puddle lights on the mirrors also because I use a aftermarket alarm/fob and it does not turn the puddle lights on.
mikez71
l
Great info Doubeleive!
I knew I shouldn't respond to Denali/Escalade question...
Smityinms
