2007 denali oil pressure questions. *video posted*
ny_summit
i have a 2007 denali with 97k miles. i recently changed the oil pan gasket because of a leak. i swapped the whole pick up tube with a new tube and o-ring. i also blocked off the oil relief valve.
now the issue. my friend (the mechanic) found 2 small pieces of metal which be believes are from the cam bearings. does my oil pressures reflect bad cam bearings?
my cold psi is great at 60 psi. my cruising psi seems to be around 35-40 psi depending on RPM. my hot idle after a decent trip is around 15 psi.
i just found out i can get an oil pressure gauge on my torque app. the video posted shows the idle psi as well as revving it in neutral. i will get another video if the pressure when im actually driving.
j91z28d1
do you have any pics of the metal found?
15 isn't at bad as others. do you have afm delete stuff?
donjetman
your oil pressure is fine
ny_summit
ny_summit
Unfortunately we didn't take any photos. 1 piece was pretty small to tell where it's from. The other be believes had copper on it. My Denali did not come with afm from factory.
j91z28d1
ahh. you're fine.
B-train
I wouldn't sweat it. Those motors also have 8 o-rings under the valley cover that get hard and start allowing oil pressure to bleed off. Super easy fix. While you do that, put in a new GM oil pressure sender. Valley cover o-rings (or stand pipe/afm oil ports that aren't used on your engine) can cause quite a drop in PSI once the oil is hot and you have 8 areas of seepage.
Otherwise you pressure looks fine. I have a 2008 with a 6.2L, 193,500 on the clock - oil pressure is probably 50-60 cold, 30-40 cruising at freeway speed, and 20 idling hot. I did the oil pan, pickup tube, rear main seal, and valley cover o-rings since 140k miles. Yours is pretty close to that. Those items mentioned are just common areas of leaks to look at if you're concerned.
If you ever hear lifter/valve train clatter on a hot restart, you're overdue for valley cover seals - learned that one on my 2007 Denali.
donjetman
@ny_summit
again, your oil pressure is normal.
If you want more oil pressure when hot, run a thicker/higher viscosity oil, like xx-40, xx-50, or xx-60.
I've run many different oils and viscosities in our 07 L92: 5w30, 5w40, and even 16,000+ miles with 0w20. Oil pressure has always been the same as yours.
j91z28d1
@ny_summit
I agree. bet that thing goes 200k without an issue. the looks to jump to 40psi at the slightest rpm bump.
we have big 2 generators at work that someone speced ford gas v10s instead diesels in. they call for 0w20. but if you use it they run themselves out of oil in a few weeks, and we don't schedule them for service till 400hr or 6 months, whichever comes first. so no one checks them till they won't run. engineering gave up working with the manufacturer as to why they eat 5qt a month or so of use. switched to the standard conventional 15w40 we use in the diesels and they will usually make it to the service interval.
sometimes thicker oil is the a good enough fix in the real world.
West 1
Cam bearings are either Aluminum or Babbitt material. Neither has copper in the mix. Mains and Rod bearings can have copper although most newer engines run a new aluminum high silicon mix with zero copper. The EPA has been pushing hard for companies to eliminate Copper Lead and Tin from engines, EPA says they are all toxic to the environment. I guess they think we will be feeding fish our engine bearings?
nas50
