The saga of the p0011
Foggy
KS
Dang Discodisco
Sounds like you've done it right....with good parts.. but those can often be
black market knock offs from ebay/amazon. But if you got them thru regular channels
they are surely the real ones......Ugh....
Wiring circuit past the harness you replaced ??? Ground issue???
Could it be possible that the cam sprocket got 1 tooth off when you replaced it???
Sounds crazy.. I see where you're frustrated
D
Discodisco
In my 6+ yrs & 70k miles of L92 ownership I've run:
0w20
5w30
5w40
0w40
10w30
Never had an issue or made a difference in the way it runs. It has 199k miles now.
Motul is TOP tier.
The only oil filters I've used are Fram Ultra & Titanium.
Yeah I don’t see the oil being the issue
D
Discodisco
Dang Discodisco
It was off when I initially did it and immediately gave me a p0016 for cam crank correlation so I tore it back down and reset timing, no more correlation but the p0011 persists
Every time I see trouble with VVT and everything else has been checked, when queried, the wrong oil was being used.
It's in the shop manual. Obviously, not everyone has this problem as attested to by my friends here.
donjetman
I've been here (TYF 07-14 engine) for 6+ yrs and I can't remember anybody having a VVT system failure?
Other things in the timing cover area that can fail:
Timing chain, gears, and or tensioner?
Cam position sensor,
Camshaft phaser magnet
pulley and seal
D
Discodisco
pulley and seal
Of that list the only thing that hasn’t been replaced is the chain itself
D
Discodisco
Bad cam sprocket? Or is that delco also?
I don’t think so, nothing is impossible but it’s a gates sprocket which isn’t a low quality part. I spoke to a buddy who’s a gm tech and he suggested I look at some things.
D
Discodisco
For the sake of helping the next guy I’m gonna try to keep this thread informed until I have a fix or delete the vvt altogether and put a fun cam in it. I spoke to a buddy who’s a gm tech and he suggested I run a new 5v wire from the pcm to the cam sensor. He says these harnesses aren’t the best as they age which makes sense as mine has seen better days. I have checked for a 5v at the sensor previously which was good but it’s possible during operation it’s shifting and causing an open circuit. I’m going to try it Monday and see what happens. I’m slightly suspicious of the oil pressure leaking past the #2 cam bearing but I would think I’d have oil pressure issues if that was the case.
ehernande86
