Led conversion issue
01Tahoo
I have replaced all my exterior lights with leds on my 01 Tahoe and they all work except my turn signals when the headlights are on. No hyper flashing. They just only work when headlights are off. I disconnected the headlights but it didn't help. Any similar experiences/thoughts
Miami-Dade
Super Moderator
@01Tahoo Moved you here from Site News
Welcome from Miami&Queens NY!
RST Dana
OH
Can you try flipping the wires?
Welcome to the Forum from NH.
Pics of the truck, please.
As stated above, check your wires and connectors first to ensure that the connections are correct.
mountie
Welcome from SE Florida ! Pictures..... ( We are mostly guys, but including the gals... so, we are visual ! )
I have an '05 Yukon... I am considering LEDs for headlights, but concerned of the beam pattern )
Meathead16
What kind of bulbs did you use? I'm assuming 3157's LED equivalent, but might as well ask.
Do they only work when no other lights are on? Do the headlamps need to be on for them to stop working or does having only the parking lamps on do the same? Does turning the high beams on change anything? Does the instrument panel show that the signal but the bulb doesn't turn on or literally nothing?
Mikegrz
