Replacement Battery
bonegunner
I have had great luck with Duralast Gold batteries, and one lasted 8 years in our Tahoe.
I put a charger on them every couple of months, since most of our trips are short distances.
My dad taught me that around town driving is tough on batteries.
BADRIDES
I currently work PT at O'Reilly's just for the discounts and pocket change. The 'Free Replacement" of a Battery is a true statement to an extent, yes you get a free battery in the event that your battery takes a crap (for example) in the 42 month warranty period.
However, your 42 month warranty DOES NOT start over! Your warranty is only applicable to the original purchase date.
So if you bought a 42 month battery on Jan 1, 2022 and it took a crap on Jan 1, 2025 then you get a 'Free Replacement' battery with a 6 month warranty!
O'Reilly's, AutoZone, NAPA, Advance all use the EXACT TERMS for Battery warranty. Yes some stores will try and work with you and your battery needs, but don't expect or demand it! I know that O'Reilly and Autozone don't Pro Rate batteries any more and stopped doing that about 5 yrs ago, as stated above you just get a new battery (free) with a greatly reduced warranty.
Chad
GM is the same on warranty wise
EddieC
EddieC
Chad
That's fair enough. Assuming a person got 3 years out of the first one it wouldn't take much time for the replacement to make him get his original money's worth. Anything more is unreasonable.
Thrust
ICT
It's the same with Walmart. A battery replaced under warranty doesn't start the clock over.
Jetskier77
I put a Autozone Duralast Platinum AGM battery 3 years ago. I paid $250 and was able to change it in 30 minutes in front of Autozone using there tools. They offered to do it for me but I won’t allow anyone to do it because they can scratch or damage my fender or paint. Duralast and Diehard are the same brand. Diehard is a sears brand that was always the best to get. Previously I bought a GM 42 month Delco Gold non-AGM for $220 which Cadillac roadside bought to me when my original battery died. Roadside convinced me that AGM is not good for our trucks so I believed him. 8 months later the new Delco Gold battery failed and I lost the receipt. I was told I had to go to the selling dealer that roadside was sent from but I was 1200 miles from home on vacation. I was not about to call roadside every time I needed to go somewhere with my truck with my family on vacation. It is embarrassing since I always brag about how great my truck is. I went to Autozone and bought the Duralast platinum AGM and now 3 years later it is still perfect. I can go to any Autozone in the world when my battery fails and get a new battery under warranty or prorated at any location using my phone number. The Duralast also has a 140 hour reserve. I can clean my truck for hours and no loss of battery. Our trucks are fully compatible with AGM.
Autozone sells the DuraLast AGM platinum:
Advanced auto sells the Diehard AGM platinum:
They are exactly the same manufacturers just labeled different. If you ask your grandparents about how good the Diehard Sears batteries were they will tell you they are top of the line.
Well, they used to be top of the line. Not so sure anymore. The last couple of Diehards I had experienced notably shorter life than say the Diehards of decades ago.
Jetskier77
my last set of Interstate AGM's lasted me almost 5 years (even with the California heat), they probably would have made 5 years+ but I could tell they were getting weaker
Costco sells them for around $170 with a 3 year warranty.
I believe that is $10 cheaper than a standard walmart battery, last time I checked anyway
Yup, $179 plus fees ($212 out the door) for the Interstate AGM with 3 year prorated warranty.
drackill1
