Rear Hatch lock
Big Eazy
Hi..New Member here. I have a 2006 Tahoe 2WD base model. The rear hatch will not lock. I have secured a replacement assembly and will install it soon. The truck was purchased with no remotes. I bought 2 on E Bay and they will not program using the instructions on U Tube. Can the bad hatch lock be the cause of it not programming? Thanks for any help.
I have a 2004 Tahoe and mine was the opposite. The rear lift gate door would not lock. I replaced my key fob and I have not had any problems with her. It was very easy to reprogram the fob per the instructions online. I purchased the fob online at: WWW.RemotesRemotes.com.....Hope this helps! Good luck.
Super Moderator
Elev 5,280
The link you posted doesn't work -- care to edit it?
Timqua
