Engine oil pressure issue
Papawolflopez
Mi
Engine oil pressure gauge fluctuates along with lower rpm and a muffled backfire on passenger side between the speeds of 40-70 I have replaced the oil pressure switch the oil pump along with the oil pick up tube. Rearmain seal. Spark plugs
What could be the issue?
P
Papawolflopez
Mi
I took a video of what it does, but I don’t know how to add it
rdezs
Backfire.... Have we scanned for any codes? Otherwise there's a huge list of possibilities. The list gets larger if this is an AFM/DOD engine, and if VVT is in play.
After scanning for codes I think I would do a compression and leak down test to get a complete picture. If it passes that, and if there's no codes being thrown, we will need live data when it's happening.
GMT800 SUV/Trucks
Military
While you had the old switch out, why not attach a mechanical gauge with a long enough hose that allows you to come out the back of hood and tape gauge to w/s and see it? I understand the backfire but am confused about, "with lower rpm". "Between the speeds of 40-70 mph" means the backfire and lower oil pressure is when you drop to 40 mph or the engine speed will drop to 40 mph, all by itself? Very confusing description.
By the way, welcome to the forum from Oregon.
P
Papawolflopez
Mi
It is a 2007 5.3 4 x 4 LTZ also the guy I bought it from lied about mileage reads now at 127000 but really it’s 200+
Just put in newly rebuilt 4l60E
And I’m not sure of type of engine so I posted my vin
terryseverson
