Forbidden Glitter Mushroom on Transfercase drain plug
mrkev
Just thought i'd share this finding after changing out the transfercase fluid. I got the car @ 130k miles. 1 owner, dealer serviced, but I doubt they ever did the transfer case. The last time they did a trans flush as at 60k. When I go the car at 130k, the transmission had a violent Jerk when going slow from 1st to 2nd gear. The temp sensor was also intermittently not working, according to the dash readings in tow mode. I changed the fluid (mobile1) and filter i the trans. also got a new temp sensor from the dealer at 65$ (glad they didnt try to rip me off on the price) Shifts 100times smoother after i changed it. 1000 miles later, I changed the trans fluid again, without the filter and it shifts even better now.
While doing that, I did the transfercase fluid with Redline D6. Found this on the drain plug. Car runs fine.
M
mrkev
Not related, but also wrapped the exhaust that's close to the tranny pan. hopefully it will reduce some unwanted heat. I guess it wont hurt.
Silentnight008
