Accidentally purchased a denali front differential to match gearing in my rear end.
GMCChevy
Senior Member
The other problem is whats inside that the actuator is controlling? With no provision for the actuator on the awd one it might not have that either. You are probably better off to either swap the gears only like what was mentioned or get the proper part.
If you swap gears make sure they're set up properly.
If i swap the axel tube housing the actuator will it be straight forward swap or will i also need to tamper with the gears at all?
Ok, I looked up a video that I've referenced in the past and you are good to go with just changing that tube.
Go to DemandAAM.com and look up the diagram for your front axle. In there, you'll see the differences between the 4x4 and AWD front differentials.
I purchased a Denali transfer case with 3.73 gears but did not realize it doesnt have plug in for the selector switch. Is it possible to swap out some parts from my stock front diff to the denalis to make it work??
My stock rear end blew and i swapped it out last year with a junk yard part. My truck was gu6 front and back with 3.42 gears. It now has 3.73 open diff in the rear. After sourcing a front diff on offer up (cheaping out) with 3.73 i failed to realize it wasn't compatible in terms of plug and play.
Any suggestion will help? Can i rebuild it or am i better off re-selling it and getting the front diff i actually need GT4 rpo.
After reading all of the above comments, it would be much simpler if you found the correct front differential and be done with it in the form of a small project. IMO, there is no need to complicate this project to save a few dollars. Find the right front differential from a used parts house, and see if they will give you some credit for swapping the incorrect one that you have now.
j91z28d1
you're talking about just unbolting the end tube and swap them? if they are the same and it fits, I don't see what it would hurt to try.
that solenoid just locks the right wheel to the left wheel when in 4hi/4lo right? I mean if you don't use 4hi/lo often enough, maybe just pull the old actuator off the old one, plug it in and zip tie it out of the way? so it doesn't set a fault code for being unplugged.
rockola1971
Indiana (formerly IL)
I've fiddled with my 4WD... Rebuild the tx case, front diff, etc. However, I've not swapped parts from other vehicles. Not 100% sure on fitment.
That said, probably the only thing would be that actuator on the axle tube. It may need swapped if the connector doesn't fit...
The AWD TX case is an NP246. Internals are pretty much same from what I understand across the model years... However, the encoder motor is different. The split year change (2003?) has a newer style encoder motor and probably a newer style 4WD controller.
Note: You'll also need the 4WD controller as well as button selector.
Let's start with this...
Year make and model of your vehicle. Did it come with AWD? Or was 4WD only. (the AWD has a special controller)
Year make and model of donor vehicles your parts came from.
AWD unit is a Borg Warner BW4481 (BW) Tcase. Not even close to the same as a NP246 (New Process/NVG-New Venture Gear). 2 totally different companies.
rockola1971
Thanks for responding!
The axle tube housing is the only exterior difference that i can see.
I guess my next question would be if i could swap the tube housing/actuator on to the awd diff and if so would it still function the same way as stock with 2hi, 4hi and 4 low? Or will i need to modify the internals of the awd diff?
The photos below are of a 4x4 front diff and the awd diff
The only difference between the AWD and 4WD front Diff (In the same generation) is the axle housing(Passenger side), electric shift motor and the shift fork assembly. You can swap your 4WD components over to the AWD unit. Its fairly straightforward.
rockola1971
No. The shift solenoid locks the front driveshaft to the front diff.
Kungfubenny
Kungfubenny
Thank you! I figured just getting the correct part would be the most straight approach to this situation. Id hate to mess them both up in the process of frankensteining the awd.
2004BeastMode
